Does this sound like a fuel problem...
unreal
got to the lake today both motors fired up, 1st try. Then my bad side started to sputter again eventually running as poorly as before, Except this time when I could get it running it never went over 4k.
Even worse, the good side now has issues. that one started and idled well but would not go over 3500rpms.
On the water I turned carb up adjuster which got the idle over 2k and max throttle up to 4.5ish- both sides.
Tried turning out knobs on raves, that didnt help any.
After cleaning the carb out today my bad side started/idled good ... many times.
I was low on fuel at the time and got some gas before going to the lake. Could bad gas cause this. Weird that now I got issues on both sides.
back at it again...
just puled my fuel baffle. It looks pretty clean on inside but not if I should be looking for something in particular. Any thoughts???
Also fro mthe baffle the return goes through a tee and to the each carb. My ret lines have fuel in them. Is that normal???
Thanks
