Twin 787s. 1st motor is fine. 2nd motor...
The carb was adjusted to 3k on trailer 1.5k in water. The motor was just rebuilt, reinstalled, compression near 150 in both cylinders.
Now when I start it cold on trailer it runs at 2k rpms for about 10 seconds then kicks up to about 3300 after 10 seconds (roughly). It seems to stay there, I shut it off after about 15-20 seconds.
On the water, it idles around 1200 rpms and sputters sometimes. Upon acceleration sputters and bogs. rpms are lower than other motor at any throttle position. At 1/3 throttle only 2kish and at half throttle around 3.5k rpms. The other motor is around 4.5 at half throttle. Full throttle on bad side will push to 4.5k.
The weird thing is at times is suddenly engages . The rpms kick up to pretty much match the good side. A couple times at or near WOT the bad side kicked in but only to around 6200rpms. It would hold there for maybe up to a minute , then sputter a bit and then back to around4-5k rpms.
The sputtering sounds only occur when its tryin to engage to the higher level of rpms.
Any ideas or comments???
Thanks
Thanks
