hmmmmmmm....?
So, after reading a bit more, I am having a hard time finding enough information for a conclusive post.
So far, I've read in one manual, that the only thing different between the two pumps is the ride shoe and inlet grate. Then, in another reference, it appears that the nozzle is different. So, now it seems further research is all I can do.
Logically, it seems with twin engines that are not counter-rotating, you'd need some handicap to even the thrust load on each motor. I see in one of the other posts, someone wants to know why. If you picture in your head, the vortex coming from one of the nozzles in a counter rotating pattern, you'll see that the "twist" of that, led by another engine, would cause a pull to the left if they were both of equal power. Like holding on to a battery powered screwdriver when using it. If your putting in a screw, the torque is pulling your hand to the left. If you had to powered screw driver, one putting the screw in, one taking it out, the forces would be equal (though, you'd not meet resistance with the screw coming out).
You'll notice on boats running twin outboards, one motor spins clockwise and the other counter clockwise. This equalizes the centrifugal forces.
I'll have to go through several of the Speedster configurations to figure why it appears some have different size nozzles and others don't and why, if any reason for impellers, to be of different sizes. The progressive pitch impeller can be on both, it's the diameter of the impeller that may change.:cheers:
