I had my boat int he water yesterday and noticed that when the drive is in NEUTRAL and I rev up to 3000 RPM the boat doesn't remain stationary at all but moves slowley - mostly sideways.
I noticed when i move from neutral to reverse - no control surfaces on the back change but I can rev the engine up higher. Are there any other control surfaces behind the jet pump or in the intake that are supposed to move when the boat is in neutral??
How can the boat ever be in true 'neutral' as the impellers are hooked up to the engine - so whenever the engine turns you will always have waterflow through the pump.
Any advise is greatly appreciated.
