Did i winterize correctly?
larrybr45
Just second guessing what i did as I had to modify on the fly. I was intending to simply pour in antifreeze and pinch hoses and NOT run engine. The two hoses the manual says I was to disconnect were zip tied, and impossible to disconnect SO.....
I poured straight antifreeze in the flush connector on the top of the boat, then ran the boat. I eventually saw red water come out the exhaust and at the bottom near the reverse/forward gate in the middle of the boat. I did not see any red fluid come from the top most drain where the towing tube hooks up. I ran 2 jugs through with the engine running.
So, does it appear I will be ok and engine has been flushed and protected ok enough?
(Incidentally, I did spray the fogging oil as instructed)
thx
