Di fuel problem?
mark j
Need a little help in determining if fuel pump is my problem. Ski would run for about 5-10 minutes and then just die as if it were running out of gas. I would take the lanyard off and put back on and ski would run for just a minute or two and die once again. It seems when I pressurize fuel system it runs just a short time. Question. I check fuel pressure and got around 107 psi until it dies. Can the fuel pump maintain that fuel pressure for a short time and then loose it? Any help would greatly be appreciated.
It could... but not likely.
Check over the air system... but you may have bad injectors... or a bad regulator.
