The throttle control handle literally snapped in half and I can't get the part anywhere. Any advice would be most appreciated.
View attachment 51652View attachment 51653
Did you ever get rid of that part - mine just broke offI may have what you need. I will find the box and get you the part particulars.
Did you ever get this sorted - mine has broken at the screw so will buy the handle from you?The throttle control handle literally snapped in half and I can't get the part anywhere. Any advice would be most appreciated.
I have the same issues as the others here, a broken handle. Is the Volvo Penta control unit a direct replacement or modifications required. I plan on using just the handle if it will fit the gear that the older handle uses. Any help will be appreciated. Thank You FYI 2008 SeaDoo Utopia 205 SE 430 HPIt appears to be the same throttle controls as the Volvo Penta Xact. My handle is cracked as well and they don't appear to sell replacement handles (not that that would fix your problem), so the only option is a new control.
I'd keep the trim block off plate from your current handle in case you wanted to swap it out on the new controls.
New controls are roughly $350. Give or take a few bucks.
Link to control
I actually purchased the whole assy. mentioned above (Volvo Penta 3888316) from Pro Pride Marine for $366.00 with free shipping and had the local SeaDoo Yamaha Dealer install it. It didn't work, the Tech said it had roughly 3/4 forward throttle and no reverse. I asked him if he tried just swapping the handle and he said he did but it was different also. Cost me $270 X 2 plus the price of the new control. I am not 100% sure he tried swapping handles so I am going to take a look at it today just to make sure. Thanks for your reply.West Marine sells these. The BRP assembly might be a “hybrid” style, but I’d bet money the lever is the same regardless of the cable mechanism.
That's a great work around, I will keep hunting for a solution, my handly snapped off clean at hte top of the polished section.A freind who is a mchinist, mad this cutom colllar which got me back working again. My plastic handle was only partly broken, so there was a little meat left to re-inforce. I also now hold the stick lower to put less stress when shifting/throttling.
BTW- my 2011 SP210 is for sale.
Interested in your solution if you managed to find one with full throttle.I actually purchased the whole assy. mentioned above (Volvo Penta 3888316) from Pro Pride Marine for $366.00 with free shipping and had the local SeaDoo Yamaha Dealer install it. It didn't work, the Tech said it had roughly 3/4 forward throttle and no reverse. I asked him if he tried just swapping the handle and he said he did but it was different also. Cost me $270 X 2 plus the price of the new control. I am not 100% sure he tried swapping handles so I am going to take a look at it today just to make sure. Thanks for your reply.
How did you make out with swapping the handle/lever? Mine snapped and this is the best option I've found so far. Would like to know if it's worth buy the Volvo controller.I actually purchased the whole assy. mentioned above (Volvo Penta 3888316) from Pro Pride Marine for $366.00 with free shipping and had the local SeaDoo Yamaha Dealer install it. It didn't work, the Tech said it had roughly 3/4 forward throttle and no reverse. I asked him if he tried just swapping the handle and he said he did but it was different also. Cost me $270 X 2 plus the price of the new control. I am not 100% sure he tried swapping handles so I am going to take a look at it today just to make sure. Thanks for your reply.
Hi I have an 08 Utopia 205 and my control handle also is broken which one of the controls on west marine will work? There are a few that look similarWest Marine sells these. The BRP assembly might be a “hybrid” style, but I’d bet money the lever is the same regardless of the cable mechanism.
I am as well or my boat is worthless!Interested in your solution if you managed to find one with full throttle.
Any word back from your mechanic on this repair approach?I just sent that Volvo one to the mechanic I will let you know when its repaired. If not I was wondering if anyone was able to get theirs fixed
