Nathan Mayo
My '97 Speedster has been giving me the fits, so I caved in and took it to my local Seadoo dealer. Several of the local shadetree mechanics have failed. Greg, the head dog at Seminole Powersports, is a knowledgeable prince of a guy and has the tenacity of a bulldog. He discovered 2 clogged up accelerator valves and could not clear them. Since they are $200 each X 2 to buy new I tackled the job with my office ultrasonic and managed to clean them up after 5 solid hours of buzzing with carb cleaner and PB Blaster, followed by white vinegar and Limeaway. My latest effort tonight was 4 more hours on one of the carb bodies. I think the passageways are now totally clear, but he will have to reassemble and put it in the lake to test.
I realize that most people do not have access to such a device and they cost several hundred dollars for a good one, but all dental offices have them. You should all be on good terms with your personal dentist anyway, so maybe if he is an understanding boat lover he could let you come over and use his. If not, maybe some motor shops have them. If this all goes well I will try to talk Greg into getting one for his shop. I suspect a lot of carb problems could be solved fairly easily with one of these gadgets.
Carb cleaners mainly work on organic gunky stuff...........my problems were caused by calcium deposits or aluminum corrosion products in some very tight little crevices. Acid wash and ultrasonic is the only thing I could think of that would have a chance at loosening them up.
