monteburns
Hi All,
Long time Seadoo owner, but I've got an issue that has me a bit perplexed.
The machine in question is a 2002 GTX 4-Tec Limited, NA. 137 hours.
History:
I purchased the machine from a guy a little over a year ago. At the time it was not running very well, so I did a compression check on each cylinder prior to buying it and all three cylinders were almost exactly the same. The gauge I used showed between 150 and 155 PSI for all three.
I ran it once on the lake and ran for awhile but not very well. The impeller and wear ring were beat so I replaced both of those.
Next time on the lake, I took off from the dock. Went pretty well, but not as fast as a 155 normally goes. Couldn't get above 45 MPH on the clock. After only 10 minutes or so the engine started losing RPMs to the point that it just died. When attempting to start, it would crank and not turn over. We towed it in (slowly). I was able to start it but it never really ran well again. Put a new battery in it because it wouldn't hold a charge. Thinking it was something electrical like a voltage regulator, I took it to the dealer last week.
Dealer Response:
Dealer calls me and says that he was able to get it started in the shop on the hose, but couldn't keep it going. Ran it long enough to check codes, there are none. Tells me there are some metal bits in the oil filter and that he felt like the engine needed to be replaced. He said compression was good on all three cylinders but that the third cylinder was a bit lower than the other two. He said the electrical all seemed to be in good shape, though I don't think he ran it long enough to do any electrical tests.
What perplexes me is this: if compression is good and the engine will turn over, does that indicate a trashed engine? It doesn't backfire or blow smoke either. I can't imagine what would be broken in the engine that would warrant a replacement if the engine isn't seized.
Anyway, before I throw tons of money at this, wondered what the community thinks?
Thanks in advance!
History:
Dealer Response:
Thanks in advance!
