Was out for a ride today and everything appeared to be fine after 30 minutes or so of fast riding. Slowed down to an idle to take a drink of water, then applied full throttle to take off again. The engine itself appeared to rev ok, but very little propulsion.
Found the wear ring broken up in large and small black, plastic fragments inside the impeller housing just to the rear of the impeller. I'm assuming some kind of foreign object got jammed in between the wear ring and the impeller on my '96 SPX, forcing the wear ring out of position, and subsequently destroying it.
I've got the shop manual, but I'm not quite sure just how much I have to disassemble to replace the wear ring. Assuming my impeller is ok, can I replace the wear ring by just removing the impeller housing from the outside rear of the craft? Or, do I have to remove the impeller housing, (drive) shaft, and impeller to replace the wear ring?
Thanks!
Thanks!
