statikuz
Hey everyone. I posted about this problem quite awhile ago but I couldn't resurrect that thread so here we go again.
Original thread: RAVE valves - damaged valve and piston, water in oil?
I haven't ridden them much since then but decided to get to the bottom of this. I knew it was already in rough shape so I did a compression test. 60 psi mag and 110 psi PTO on a freshly charged battery.
I took the head off and this is what I discovered:
https://photos.app.goo.gl/kaRfaGSJdhApDyKA7
Obviously it needs work, so the next step I guess is to pull the cylinders which might be a chore since I don't really have the capability to get the whole engine out.
Any ideas what could have caused this in the first place? I don't want to spend money on parts and just destroy the next piston too. It has about 140 hours.
I also have a 2003 RX DI that is in pretty decent shape, it is 124/124 psi compression.
