Crankshaft Bearing Problem
kmckee
Hello,
I have a 1996 Sea Doo GSX. I am in the middle of a top end overhaul for the 787, and have discovered that the MAG side crankshaft bearing cage has been destroyed. I am getting differing opinions as to whether or not I should just replace the bearing, or replace the entire crankshaft. Any advice on this?
Thanks,
Keith
well rule of thumb with all old timers and gear heads has always been, you split the case you replace all the bearings, its one of things you wish you would of done when the next bearing goes out in the middle of the lake
