Doing a pressure test on a 717 that I just had to rebuild the top end on because of a piston failure.
I think the failure was due to lubrication since it only affected one cylinder, however I wanted to do a pressure test to see if the outer crank seals were leaking.
So I made some block off plates and I pressure tested the intake and verified that Eric escaped out the pulse hose.
From what I understand it should hold 5 PSI for 3 minutes. I found that it does leak about a half of PSI in that time but it'll hold at least two to three psi for 20 minutes or so.
I also pumped it up to 10 PSI, In the first three minutes it loses a few psi but it still takes 20 to 30 minutes to completely leak down.
Obviously that is a minor leak, but is it big enough to worry about? I mean I imagine that's not really enough volume of air to cause a lien condition?
as far as the lubrication issue, I'm not really sure what happened I'm thinking when I disconnected the lines I failed to bleed the pump. Both squirters have oil in their lines. I guess I'll use a tank of premix and water test it.
