Really? Dry? it needs something otherwise it can leak.. usually 518 works fine, or TB 1184.Outside of the seal should be clean and dry.
These crank seals should go in with no sealant on the outer rubber casing. That's why they are rubber cased, the rubber is what seals. The only part of the seal that gets anything is grease on the inner surfaces so they don't burn up from a dry start.Really? Dry? it needs something otherwise it can leak.. usually 518 works fine, or TB 1184.
No, that is wrong, the seals go on dry. That's why they are rubber cased, the rubber is what seals. The only part of the seal that gets anything is grease on the inner surfaces so they don't burn up from a dry start.
This is how all of the watercraft crank seals are made, Yamaha, Kawasaki, Fuji, Seadoo.
And same thing in the automotive world, cam seals, crankshaft seals, driveshaft seals, transmission input shaft seals, etc. Rubberized on the outside....and builders still use a sealant against the case during assembly. Not sure why you wouldn't on a jet ski engine..
It's an extra measure or piece of mind, that's all, it doesn't hurt one bit... It might not be a manufacturing process, but it's an assembly technique that's widely applied..
