craigster0128
2002 sea doo water spraying from exhaust side of engine. I tried to crank the engine over in my drive and it wouldn't turn at all. I charged battery, removed plugs and tried a crank and noticed water spitting out of spark plug holes. Cleaned plugs, put back in and cranked again. This time it turned over fine buit still wouldn't start. I turned the water on in flush port and kept trying to start engine. After about 3-4 minutes the engine turned over and ran great. I let it idle for 3-5 minutes with water running. I checked engine compartment and noticed quite a bit of water in the bottom and it felt oily. After looking closer I noticed the water was spraying out of the exhaust side of the engine. Is this normal?? What have I done or what can I do to repair this?
Thanks,
Thanks,
