bodine465
Since I'm replacing the crank in my 96 GTX, I was thinking about replacing the rotary shaft seal. Looks like the brass gear and spring are held in place by a couple of circlips, but is the bearing pressed on the shaft? Can the seal be replaced without taking it to a machine shop?
Second, one of the seal on the counter-balance shaft looks ratty on the outside, like it was torn on installation. The interior sealing surface looks fine and the other seal appears undamaged. This definitely looks like it needs to got to a machine shop to press off the counter-balancer to get to the seals. Would it be ok to use a sealing compound on the damaged part of the seal when installing to keep from having to buy a rebuild shaft?
