Could it be my Rev Limiter?
undem
2000 gti
On cold start front cylinder inop-intermittent. After no more than ten minutes runs ruff then runs fine. Runs fine rest of the day. Any ideas? New plugs, good fuel, cleaned fuel filter, compression even.
Tod
yup, at the plug end. It works, cause over time, corrosion sets in under the boots, eliminating the spark to reach the plug, along with, the wires insidethe insulation, gets corroded and jammed back. So, cut'n it, exposes a new/clean contact, for spark to travel.
