I have a 97 gti with a 2 1/2 year old engine in it. Ran great last two years. A couple week ago I took it out the engine would cut out and run hot. When cutting out I let off the throttle and it would idle back up just fine and run great for a while. If it did die it would always start back up no problem. I had seen the old grey fuel lines were still in it so I replaced all those and the carb was actually really clean when i took it apart. I put everything back together and turned it over and it did fire up for a second or two then died. I then put fuel mix in carb and tried firing it up again knowing it may take a few times to get pressure in the system to keep it running. Well aftor trying it for a while nothing. So I checked the compresion and it was 90 in both. My question is is ran great when i took it it out with full power until I ran it toppend for a while and it got hot. I would think it wouldn't have run well when i had it out with low compression. Does the compression get bad that fast? I will try another compression testor just to make sure my dads old one is not faulty. O
O yes. I does have spark
