Frank_Hassa
This is my neighbor's SeaDoo. He's getting ready to work on it after it's sat unused for years. Inside the Impeller Housing are many small chunks of thick, black plastic. They all have a slight, spherical curve to them, as if they originally came off some kind of shroud. The owner thinks that possibly neighborhood kids might have just shoved plastic inside the impeller, but wants to know for certain in case something inside is broken and needs to be replaced. The plastic is weak, and brittle. You can snap the pieces in half with just moderate hand pressure. The photo is about 1/4 the total number of plastic chunks inside, to give some sense of how large the plastic piece might have been before it was broken into all these smaller pieces.
The owner thinks it's a 1995, and a 650, maybe a "657" cc engine. He also thinks the sticker in the photo is the "serial number", or possibly the model number, but when I ran the text on Google I came up with no result.
Second, the one photo shows two gaskets on the yellow seat. One is for the box holding the "electronics" and I can't remember what he said the other one was for. Both are broken. His theory is that the previous owner thought they should be placed inside the hole before the cover was inserted, instead of being placed on the cover before both were inserted at the same time. The rubber is still pliable, but obviously old. He says he's looked for these replacement gaskets and could not find any. Looking to find a source for these replacement parts, else the only other idea is to "super glue" the ends together and put them back in service as is.
Any help appreciated, and thanks in advance.
