checking fuel pressure on DI...
timmyboy76
thought i'd throw this out, for the DI owners...
Unhook the two oetiker clamps directly outside the pump module on top of the tank. Install a t fitting in between the module and the hose. Put a 200 psi capable guage on the t(IF you want to check it on the water, use 3 feet of hose and run it through the console hole). Install the key... You should have about 120 psi(117). If the pressure drops when you stall, pressure is your problem.
Off the top of my head, I remember the pressure being 107 psi, +/- 2 psi. Someone should check the manual to be sure.
