timmyboy76
thought i'd throw this out, for the DI owners...
Unhook the two oetiker clamps directly outside the pump module on top of the tank. Install a t fitting in between the module and the hose. Put a 200 psi capable guage on the t(IF you want to check it on the water, use 3 feet of hose and run it through the console hole). Install the key... You should have about 120 psi(117). If the pressure drops when you stall, pressure is your problem.
