drunkenmaster
Have a 04 speedster 200 with a cavitation issue on one motor.
When I take off it winds up to the rev limiter (just one engine) Also that same motor will run about 7300 RPM at wide open throttle while the other runs in the 6200 range. Wear rings were a little worn so I replaced them. I also replaced the carbon seals although I'm not sure it was needed. Still have the same issue. The impeller has a couple of what I would consider small blemishes on the outer edges if that helps, not sure if thats an issue or not.
What is normal RPM range for this boat at WOT?
