carbs
super1c
Got a 1995 GTX that im cleaning the carbs for the first time. I understand the fuel screws but my high's dont have the caps. Looks like they havent been touched before, original looking grease and they were at 0. Question is do you need those caps? Do i have to worry about the screws moving from vibration and such? And what kind of grease should i use when reinstalling screws on the o rings like in the how to on this fourm? Thanks CCC
PS Everything stock if it matters
Stock is really good with seadoo, they engineer everything to work together so the prop is about it for mods unless you want to blueprint the rotating and sliding parts costing twice the cost of a normal motor and then offering 2 or 3 miles per hour increase, I think you have the carbs with shafts sideways which is easier to tune than the model with the straight thru shafts, 1/8 turn open is about all I would go, it calls for the screws to be closed.
