Carbon seal to tight?
Sydney118
I have a 2013 gtr 215 that just got the carbon seal replaced it seems to be pressed to hard against the driveshaft support ring, on first fire up carbon ring I believe started smoking and was extremely hot. How would I adjust tension on ring (the driveshaft support collar is boiling hot when running at idle in driveway)
It’s not adjustable, during engine alignment check there is a measurement to make sure the engine position for and aft is correct
Other than that the bellows should be positioned correctly the impeller spline cavity empty except grease and engine coupling should have nothing inside except a rubber plug on end of shaft item 38 below and item 11 and 9 inside crank coupling 1569692969769.png
