newb2jetski
Help! I have a 1996 Sea Doo XP. Notice during last ride that I had taken on water. Upon inspection, found that the fiberglass thru-hull fitting cracked and the drive shaft boot was no longer attached. I have figured out how to replace the thru-hull fitting and have taken off the pump and drive shaft. (The drive shaft and pump came out as one piece...) My question is that the parts forward of the thru-hull fitting don't seem to match the 1996 XP parts list. Specifically, I do not have a support ring or carbon ring (and did not find a c-clip), and I do not have a bellow.
Rather, I have a drive shaft/bearing seal carrier with a "smooth" drive shaft boot. The boot and oetiker/tridon clamps on the flywheel are there, however. My thought was that I could simply reinstall everything once I get the thru hull fitting in place, but was wondering if it makes sense to replace the seal carrier, or if I should try to switch over to the carbon ring set-up (if that is even possible with the shaft I have?) Finally, there are a few videos out there to show how to reinstall the shaft with the carbon ring, but I can't find anything to show how to reinstall the shaft with the bearing seal carrier (and not sure how that is kept from rotating with the shaft...). I also did not see the plugs on either end of the shaft (could these still be in the flywheel and the pump assembly?)
Can anyone provide advice, instruction, pictures, a video, or step-by-step instructions??? (the 1996 shop manual was absolutely no help)
Thanks!
Thanks!
