artr
I want to inspect and replace (if needed) the carbon seal and ring seal carrier (hat) to get rid of cavitation on hard acceleration from stand still on my 96 GTX. I had previously inspected the impeller clearance, condition, wear ring and installed a neoprene seal. I also tried tightening the band clamps on the carbon ring and boot. None of these corrected the cavitation. It is worth noting I do not observe water leakage from the carbon seal or boot. I have searched and looked at information on carbon ring inspection/replacement from the forum and some other youtube videos. Most of the forum material talks about leaving the jet pump attached and applying a lot of force by hand or with leverage to get the ring seal carrier to move back to expose and move the o-ring or c-clip that is on the drive shaft. Some mention using some penetrating oil if the ring seal carrier seems stuck to the drive shaft which I think mine is. I’ve watched a couple of youtube videos which recommend removing the jet pump first, putting some wooden braces in between the PTO flywheel and ring seal carrier, then tapping on the end of the drive shaft to get it to move forward into the PTO and the c-clip will be exposed without applying a lot of force. I have the following questions:
Has anyone tried the method of removing the jet pump first and then tapping on the driveshaft? It seems like it less trouble and easier but maybe something can be damaged by using that method.
I’ve seen a recommendation to move the boot a little forward where it mounts to the hull in order to increase pressure on the carbon ring to ring seal carrier. Is this really worth it or is it just putting off the replacement of the carbon seal/ring seal carrier and boot? I tried to move my boot forward without removing the c-clip and it would not budge by hand.
Thanks for any advice
