Listen to the tech's,,,Miki,,,and company,,,they have tons of experience,,,your motor is not going to run right, if at all!,,,change the top end,,,it's messed,,,then go through the carbs with a fine toothed comb,
If it's not on premix, check that the oil pump is working properly throughout its full range,,,You need to find out what caused your problems,,,it's like doing an autops,,,on any motor repair,,,I will do an autopsy of the dead body/motor,,,no guess work...hundreds of dollars and countless hours are at stake! I can't rebuild a motor for the customer, without being able to tell him why it failed in the first place,,,otherwise, the cycle will repeat,
