1996 GSX complete rebuild, Let's just say I checked everything and I've been fighting these "new carbs." They have accelerator pumps. The ski is difficult to start. When I gave it more fuel through the low speed adjusters it improved a degree but still very difficult on the low end. I moved the 67.5 jets to 70 and I am probably 2 turns out on the low speed adjusters... I can't see.
Took the ski to the water and it feels like it is losing a cylinder around 3000 rpm. A gentle jab on the throttle and it picks right up. Likely a squirt of fuel from the accelerator pump alleviates the problem. Problem seems to be at 3k and I'll call it a flat spot. It feels like only one cylinder but I'm not going the "it feels like route'
If let of the throttle the engine will continue to run pretty well. Top end is terrific, ski is strong.
I'm wondering about quality control on these carbs. They came with different main jets (140) and (142.5) and (67.5) low speed. Switching to the (70) low speed made it better in the shop. I lowered the pop-off which my gauge had at 43 psi. I reset pop off with the 80 gram spring and I'm reading 33. My gauge could be off. I have a couple of options but I'm not sure what will happen. I could lower pop-off again and shoot for another 5 psi. Has anyone had to install (72.5) jets ?
I tested the fuel system, replaced the fuel selector and pressurized the system. It just seems the ski is not getting fuel. Help suggestions are appreciated.
NOTE: I have another set of carbs for this ski and I'm very tempted to go through them and put them on. I just don't want to do all that work.
