nerdlinger
99 XP Limited, 951.
Sorry for the long post, but some background info is necessary for my question.
I do most of the maintenance for my XP, but when it comes to carbs I know very little. I'm currently in the middle of fixing a broken starter mount bolt, and since I had to take the carbs off to do it I figured that it would be a good time to clean them. However, after reading other posts and the service manual I'm not sure I want to do it with all of the details of speed screws, pop off pressure, needle valves, etc.
I changed the gray fuel lines leading to and from the carburetor, and although it is 10 years old and has probably 150+ hours on it there was only a small amount of green gunk on the ends of the lines where they connect on the plastic fittings. No gunk in the actual lines (I split them lengthwise to check), and the fuel filter had no gunk and had only some little brown bits of material in it.
I've read other posts where people clean carbs or rebuild them and then can't start their ski again. Mine runs great except for the starter issue. Top speed 60 mph.
That said, my questions are:
1) Can I change the carb filter without having to do anything else?
2) If I'm mechanically-inclined, but carb dumb, is there a good chance I might do something that turns out poorly if I take them apart to clean them.
Any help or advice is appreciated.
