pcmandevon
I have a set of 38mm carbs for my 787, I remember seeing that these should run the engine just fine with the jets changed or the screw settings changed... I don't remember what they should be and I can't find the thread. So has anyone used 38mm carbs on a 787, and if so what jets do you have and what do you have the screws set at? I would really like to avoid buying the 40mm carbs. Thank you for the help. Devon. :bigear:
P.S. The fuel pump on the MAG carb is messed up, I have access to a dual Mikuni fuel pump and a block-off plate. Is it possible to over supply fuel to the carbs?
