fearthisinc
Ok.. So I am really wanting to add a wired remote to my factory system along with an ipod cable.. The Jensen radio that came with the boat is not the greatest but i think i may just upgrade speakers and add an amp but figure ill just keep the headunit.. but definately would like to add the wired remote so i can change stations, track, volume, etc from the driver seat.. i got the cutout size off the Jensen website but for the life of me found nowhere to put it.. it needs almost a 3 inch cutout to fit.. so i was circling the boat and found only one spot where it will be easily accessible and fit wihtout a problem.. but the only issue i have is the integrity of the overall boat and whatnot as i dont want to cause damage to anything.. i mean i have seen guys on here make cutouts for speakers and whatnot so i dont think it will be a problem.. but like i said i dont want to cut it out and then find out later that now if any pressure is put on that area it will just start cracking and ruin the boat and whatnot.. also didnt want to have problems with water leaking or anything.. well anyway.. the spot is the angled piece right in front of the throttle and foward/neutral/reverse levers... i put both levers all the way foward and look like it will have more then enough clearance where it wont hit the remote or anything.. and (depending on whats behind that) i should be able to run the cable from the remote and just feed it through the side and find a spot to come into the area behind the cluster.. i will see that once i unscrew the throttles baseplate and take a peek.. but main concern is finding out if i can cut through that safely.. here is a pic of the area im talking about..
X marks the spot...
X marks the spot...
