campinitos
Does anybody know where I could source cageless needle bearings for my 93 XP with thrust washers for the con rods?
I have bought some caged bearings according to model number and year but they don't fit, so I think the crank installed may not be original. When I stripped it down there were brass bearings in place, and one had started to shear, so no original needle bearings as expected. There appears to be no other damage, so I was hoping to renew the bearings without renewing the whole crank.
To give you an idea of size, the diameter of the inside of the conrod is 21.5mm. The piston pin thickness measures 20mm. This leaves me with a 1.5mm gap to fit the needle bearings in, which will need to measure <0.75mm each.
I've tried so many dealers but everybody seems to sell the caged bearings only, which I know don't fit.
Any help would be greatly appreciated.
Cheers
Cheers
