kevinz
Hi everyone, my name is Kevin. I am buying a 96-ish GTi on Thursday for $150 w/ a trailer. I'm really only after the trailer, but it comes with the ski so I think I'll take it, too.:thumbsup: Anyway, just trying to get some preliminary thinking going on regarding it based on what the seller told me.
I did look at it today, and it appears that minus the battery, it's all there are fairly clean. The hood has a couple cracks in it but it isn't a huge deal. Overall, the ski doesn't look bad for a machine that has sat outside for at least the past year, that's how long I've seen it sitting there.
The seller said it "needs a new key fob". I did a little research here and if it is indeed a 1996 or newer (based on the hull, I think the newest it can be is a 96) it has the DESS system. He claims to have tinkered with it some and got it to crank to check compression (which he says is fine BTW), but I've read that it won't crank if the DESS doesn't see the correct key for the ski. Is that true? I've also read that the system can't be bypassed and I would need to go to a dealer to rectify it. There are two sea-doo dealers fairly close to me; both are within an hour.
I'd like to see if I can get it to crank as it should and then move to diag why it won't start; could be a number of things but I'll start simple. I figure for $150, I can afford to spend some time looking into it. Who knows, it may turn out to have some promise and if I can get a couple years out of it, I feel I'd get my money's worth, especially with a trailer I can reuse.
Thanks!
Thanks!
