jdanthony
I think I have a fuel issue,, so here's what I do so far... 02 GTI le , 717 single carb.
Took carbs off, new everything except the pop off cause I don't have a tool. Inside carbs were super clean. Reinstalled
Cleaned fuel filter
Ran on both reg and reserve ( no noticeable difference )
No grey fuel lines (all black)
Compression check 135/135 (getting a little tired I know)
New plugs ( burning really good)
Aftermarket air filter
Got it in the water, set low to 1 turn and high to 0. Set idle in the water , runs great! As soon as I hit the throttle in wants to go but Boggs and won't make top speed. I tried adjusting low and high 1/4 at a time , but the only thing that works is if I pull th choke a little bit it pops right up and runs amazing!
Cleaned fuel filter
