chazdo2
My 1998 GTX limited is blowing the 15 amp battery fuse in the rear elec. box and sometimes the 15 amp battery fuse next to the MPEM. I have had this problem before and it was the stator windings being shorted to ground. replaced the stator and problem resolved. The resistance check on the stator is fine. I do a battery disconnected test from the battery rear 15 amp fuse to ground and I have no short. ( with the bad stator it was showing a short to ground untill I disconnected the stator connector) easy find. This problem is intermittent. Sometimes after replacing the fuse it will start and run for a while. Then with no pattern or time the second or 5th time you try to start it the fuse blows. Sometimes it blows even before you try to use the starter. Anybody have any similar problem that I can start my troubleshoting trek on? Nothing more fun than troubleshooting intermittent electrical problems!!!
