Sportster LE 2000 / 951 CC engine
Long story short, pulled the head to investigate zero compression in the rear cylinder and found a hole in the piston at the circumference at about 4 oclock position looking down from the front of the boat. The hole was triangular in shape, about 3/4 inch around the cylinder wall and 1/4 inch towards the centre of the piston. Smooth surface.
Small bits of ring stuck to the cylinder dome, but otherwise the piston looked normal except for the hole, ie no alumimum spatter, spark plug was dirty but not burnt. No scoring on the cylinder wall. The other cylinder looked fine.
Boat was running fine up to that point with the exception of some hard starting issues. WOT it was running normally. On the way back it just lost power.
My questions are:
1. Why might this have happened?
2. Can I just rebuild the top end or might I need to do something else? Obviously I need to find and correct the underlying problem.
Additional info. At the beginning of the season , had contaminated gas. Would not start.
Had to drain out and replace gas. After that no issues.
Engine has less than 100 hours.
Thanks
My questions are:
Thanks
