I have my carbs off for rebuild and I am going to replace the small oil lines too. Does it make any sense to pull the plugs out and crank it with the carbs off to bleed the lines. I did not replace the larger supply line so the pump will not need to be bled. I can hold the pump full open and crank it to see oil being pushed through the lines this way.
