PGHMAN
Morning guys. Need some advice on my ETX 16L battery specs. I recently took the battery to Advance Auto for a load test (was off the Tender for 5 days) the counter person indicated that the CCA were 373 (opposed to the stated CCA of 325) voltage 12.49 and that the battery was defective. I have monitored the battery the past several weeks and note the following:
After 1 hour off the Battery Tender Junior the voltage reads 12.71
Two to three days voltage reads 12.62
After four days up through seven plus pretty steady in the 12.56 range
I know batteries are inexpensive and will replace if necessary but wanted to see if anyone could confirm based on your findings.
Thanks.
Thanks.
