RESTO Bad gas
me757
99 gti replaced gray fuel lines, and looked in gas tank yellow gas? Is that a concern? Is this normal? Drained gas about to refill
Does it stink like skunk pizz? Really bad idea to run stale fuel in any 2-stroke and think about it, marine engines are under heavy load burning 12GPH (and more) that's a lot of heat created beating those pistons like a blow torch so unstable stale fuel is the last thing you need unless you're trying to blow it up.
I was thinking maybe, maybe it was the return mixing back into the gas tank. But it was bad gas.
In all my water toys... I put Marine Stay-bil in the tank, every fill up. I've never had an issue with fuel.... EVER !! And with a 55 gallon tank in the islanda... I don't want to have to drain that.
