protrac231
Amps
Need for speed. You can just carve out an area for the speakers in the foam. I did that and it worked out great.
What i was concerned about was putting the amps in the back were the gas tank is, with all of the fumes. I would be afraid that a possible explosion due to a spark or short from the amp.
Putting in a Marine amp poses some problems because out boats dont have good grounding blocks to put the (-) lead of the amp to. YOur supposed to only have that lead be less that 16in from a ground source due to ground loops.
Has anyone had good luck running longer (-) cables back to the battery??? Any suggestions?
