The Pink antifreeze is ok for winterizing the intercooler and exhaust system... the trick is to pump it thru the intercooler and exhaust cooling system in general so as to replace the water in there with the pink antifreeze. To do this, get the cheapest electric bilge pump you can find and a ~6 foot piece of waterhose with an end on it that you can screw onto the flush port of your PWC. Lengthen the power leads and put ends on them so you can clip them onto your battery. Take a gallon plastic jug (that's clean inside) and cut it so you can submerge this bilge pump with hose attached in the pink stuff (or use a clean pan if you have one that'll hold at least 1 gallon of antifreeze). Have about 2 gallons of pink antifreeze on hand for this job.
Note: You may want to spray fogging oil into the throttle body while performing the "pink flush" of the system described next... I do! There is a little capped line on top of your 4TEC engine which goes into the throttle body, it's purpose is for you to be able to spray fogging oil into the intake while the engine is running so as to coat the exhaust valves with an oily fog so they won't corrode during the winter. Locate the capped line (it's yellow on my '06 RXT with a little yellow cap) pop the cap off and stick the tube from the fogging oil spray can into the line making sure it will stay put... during the next step, while the bilge pump is pumping pink antifreeze thru the running engine's intercooler and exhaust system, you can spray fogging oil into the intake thru this line for about 30 seconds (it'll make the exhaust smoke pretty good once the spray reaches the cyclinders, which is by design it makes for a fog of oil in the exhaust to coat everything).
So now, with the waterhose from the bilge pump attached to the flush port of your watercraft, start your engine and THEN connect the bilge leads to your battery so that the pump begins pumping the antifreeze into the flush port of your Seadoo. As the container get's low on antifreeze add more from the 2nd gallon of antifreeze till the discharge of water out your exhaust turns pinkish (should take most of the 2 gallons to accomplish this). If you want be spraying fogging oil into the intake while the engine is running and pink antifreeze is flowing into the system. Disconnect the bilge pump and turn off your engine once all of the 2 gallons of antifreeze have been pumped thru the system. You're now done with this part or winterizing!
Don't forget to pull your spark plugs and spray fogging oil into each cylinder (HOLD the red spray tube of the fogging oil can with your other hand while spraying so that it doesn't pop off and fall down into the spark plug hole!!!!). Best to go back with brand new spark plugs at this time, then dry-crank (holding WOT) for 15 seconds or so to spread the oil around inside the cylinders. Now change your engine oil and oil filter as well (it should be changed at least once a year no matter how many hours you ran the engine).
Once fully winterized, don't start the engine again till next boating season!!!
Disconnect the ground battery terminal (or you may want to entirely remove the battery and take it into a temp controlled building for the winter in northern areas... here in Texas we don't get that cold for that long so I leave my battery in the hull but disconnected from the electrical system). Finally cover and store the SeaDoo for the winter, it'll be just fine now. Occassionally on pretty dryer days take the cover off and remove the seats for a few hours to let the hull "breath" (so it can get fresh air inside the hull and any moisture out of there... I try to do this every 2 weeks or so for 1 afternoon at least).
Every 3 years drain your engine's closed-loop cooling system and refill with fresh GREEN antifreeze (available whereever PWC's or ATV's are sold, any brand for PWC or ATV use will work just fine). Keep in mind when refilled the system will need to "burp" some air pockets out so fill to full on the bottle initially then check after first ~30 minutes of riding and refill to hot mark on bottle (the bottle will go almost empty as the system "burps" out trapped air pockets that 1st ~30 minutes of riding).
- Michael
Went to canadiantire to get some RV antifreeze. But noticed that anything there (three different brands) specifically said that it does not bond with water and if put with water then water will stay separated and will still freeze. This sounds like a problem. Can anyone recommend an antifreeze brand. Should I use something automotive maybe?
