One more story about the Doo that flipped over.
If the engine ingested water and it was not taken out, the water may have rusted the bearings in the crankshaft (CS).
An easy way to check for such a problem is to turn the PTO (round wheel at end of engine facing the rear) is to turn the wheel by hand. If it turns easily, then there may be no problem.
Next, pull a spark plug, crank the engine, and see if water expels form the plug hole.
If not water, do a compression check on each cylinder (spark plug holes)
Compression should be between 140 to 150 lbs, maybe a 10-% less, but not less than a 5% difference between each cylinders.
DISCLAIMER:  I am only a Shade Tree mechanic and there are many more knowledgeable members on this site than me, i.e, SeaDooScipe, SeaDooya, etc., so, keep my comments in mind when reading my mechanical opinions.
That said, being a lawyer/teacher, I did give you very good advice on how to go about purchasing any PWC.
On that note, it is not practical to test drive the PWC before you purchase, draft a contract that spells out a clear guarantee that the PWC are in top mechanical condition and free from defects.
Often people sell their toys because they lost interest, lost a job, or, in just as many cases, there is a major problem with the PWC, or a perceived major problem that can easily be repaired if time is taken to learn how to perform the task.
I hope you find this Post helpful.
One last thought.  If the seller was using a TCW3 oil in a SD, he either was skimping on spending money OR, he is an oil expert.
