Hopefully I can get some help here. I searched, but didn't see anything that match my problem closely. Here's the story:
I de-winterized my 99 Sportster 1800 a few weeks ago. Both engines cranked right up after purging the foggin oil and a couple tries on the starters. So far so good. I pull the pumps and replace the oil and seals. Reinstall the pumps last weekend and crank the engines. No issues. Replaced the sacrificial anode and cranked the engines for a final time yesterday.
I've been around seadoos for a long time, so I know not to run them without water. never did I let them run for more than 10 seconds.
Anyway, I go to crank the port engine this morning and it turns over, but doesn't start. Starbord motor cranks fine. No issues.
I out a spark tester between the spark plug wire and the spark plug on the rear plug. That's where it got interesting. The engine cranked right up. Spark plug tester light was flashing with each spark. Puzzled, I removed the spark plug tester and replaced the spark plug wire on the spark plug. Engine didn't start. Put the tester back in-line, no start and no spark. I do get spark on the front plug.
So, a few questions:
1) how do I remove the spark plug boot? I've pulled, twisted, and it won't budge. I want to cut 1/4" off of each wire, but can't get the boots off.
2) What else would cause one plug not to get spark?
3) any other advice? Heading to the beach next weekend...
Thanks, in advance for the help.
