68ragtop
Between each winding you should see .1 to .5 ohms, but closer to .1 between each leg would be correct. .5 seems a little high even though its barely in "spec" 1 ohm is for sure high.
If you unplug the R/R, start the ski & measure the voltage across each leg it should be 35vac to 70vac from 1450-3500 rpms. If the engine is still hunting with the battery charged & the RR unplugged I doubt the voltage is causing your engine problems. while this will trigger the Maint warning having it unplugged, the idle should be smooth. low voltage is a problem, but unfortunately not the one thats causing the other issues.
Sure sounds like one leg is not producing voltage tho.
One thing to consider is an ohm meter can read good resistance & voltage across a bad connection when there is no load, but as soon as the load is put on those wires the connection fails. The corrosion you mention has me thinking it might be something like that. The GTX has two stator connections, I think? One near the mag case & one at the R/R ? Another possibility is the mag case has been compromised with water & there are problems in there. But, I would be more suspect of all the connectors outside of the engine between the three yellow wires coming out of the case, to the R/R. especially after your corrosion findings. Are you taking the plugs apart, or how are you cleaning them? Really need to nail down that voltage problem.
On the engine side of your problems, I wonder if its possible that some of the other connections have been compromised? Could be getting fluctuating readings from the manifold intake pressure sensor, or maybe from the TPS's? exhaust temp, air intake temp, etc.
Also, it's worth checking the reed valves. On a GTX, I think there is enough room to drop the throttle body down without disconnecting everything & look into the boots with a mirror? The exhaust pipe will probably make this difficult to do, but worth looking at. removing them to inspect would be best, but you can at least see if all 8 pedals are intact with a mirror, of maybe a camera? The MAP sensor is in the front boot where your lower compression cylinder is. It only reads the pressure on the mag side & assumes all is the same on the PTO side. either side could give you problems, but the Mag side I would expect would give the biggest fits because thats the side thats being measured.
I know this can be a long road diagnosing these DI's but if you check everything thoroughly & make no assumptions, it can be figured out. Just don't skip a test because it seems like its not relevant. They are all important.
