J JDusza New Member May 23, 2025 #1 Hi. I'm working on a 2001 GTX DI that has lost spark on the rear cylinder. The coil is good. So, what feeds the coil and is it something I can test before I purchase? Thank you, J
J JDusza New Member May 23, 2025 #2 If an MPEM is required, will my ignition key work or will the system need a reprogramming? Thank you, J
H hingstin Member Aug 8, 2025 #4 Swith coils and see if problem switch to the other cylinder, to be sure coil is good
