Annoying low fuel beep
Lewenda
I have searched and cant find a thread about disabling the low fuel beep on 03 RX DI. Is it possible, because it gets really annoying.
is it beeping at the wrong times? or is it beeping when it is supposed to and you just dont like it? im sure there is a way to disable it, not sure it will be too easy though. might consist of tampering with the sensor in the fuel baffle
Its beeps when it is supposed to but it gets annoying. I thought about placing some tape over the beeper, but was wondering if it could be disabled some other way. Thanks
Stop whining and put fuel in it. It’s beeping for a reason. If you disable the beeper, and you have a real problem… like over heating… you won’t know, and you will kill your engine.
umm yeah those things like to get fed to:( Would you put tape over a kids mouth that was screaming for food.:rofl:
I had a simple question that apparently was taken out of context. I do not want to totally disable the beeper, only was wondering if it could done for low fuel. I realize I can "cut the wires", but why would I want to risk that for low oil or high temps.
