Air lines ?
mihulka3
Got a 2000 GSX RFI. Do you have a picture of the tube routing inside the engine compartment?
One of the small black hoses came off and I need to know where it goes. I'm almost positive but want to be 100%
It is attached just above where the drive shaft goes to the motor and I think it goes to a three way port on the right side of the hull (viewed from front). It was the only open port I could fine that the hose would fit. My book shows no picture of it.
Thanks.
Thanks.
The RFI model uses a solenoid and air lines to run things like your RAVE valves, so I'd recommend you looking in the parts index for the correct routing. If you put this hose somewhere it doesn't belong, then you might have an engine with a hiccup...
You've also put this post in a thread that has nothing to do with your issue. I'm going to be moving it to the correct place for you.
Thanks
Checked the diagram and it appears to go to the black 3 port valve on the side of the hull. The only nipple missing a hose.
