yeah it should hold iirc 10psi for 5 minutes with the carbs all together.
Okay. So how do you plug the return port? Just a vacuum cap? Will the 10psi blow it off?
Duh...I think Strizzo is onto something. do a pop off test with the cover screwed on. I bet when you put the cover on its opening the needles and seats a little. I would think though it would run good on the high end.
So am I doing a pop off test then as well? I wouldnt think that it would change at all since the pop off since the air is pushed through the bottom of the N/S but kinda confused here.
That is correct, but I think idle in the water is like 1400 rpm. I would check to make sure that the fuel inlet of the carb is holding pressure with everything together like the others had suggested before going any further. Remember to plug the return line. If you installed all new parts from the carb kits it is possible that the little arm that opens the needle can be a little bent and hold it open once the diaphragm is installed, if you look at the manual is shows that the arm should be flush with the internal casting.
I had a similar issue last year on a friends 1995 XP, rebuilt the carbs everything checked out pop off great held pressure then he took it out and was a pain to restart after sitting and almost did not make it back to the dock. He brought it back and when we pulled the flame arrestor and added some pressure to the fuel tank you could see one of the carbs dripping. Come to think of it does yours dribble? Anyways, when I took the carb apart there was a small fiber like the bristle of a tooth brush stuck in the needle that would not let it close. I have no clue where it came from or how it got there because I don't use anything like that in my garage and the carbs passed all tests but there it was.
Correct. I was talking about 3000 on the trailer, i am not sure what it is on the water, havent had the tto on the water yet. Okay so you guys are talking about bending the arm where the little red plastic piece hits on from the Diaphragm, correct? I am not sure if that is flush with the surrounding area or not, I didnt really check. I honestly never knew what that meant to have it flush but i understand the concept now and how if too high the red peice could touch it and cause flooding
As a hobbyist I haven't seen every scenario, but I do know I personally have a hard time distinguishing lean from rich sometimes with a 2-stroke. the symptoms can be similar. What happens if you leave the throttle closed, but pull the choke for restart?
For me, I tried so hard to figure out mine by doing these things & I never got a clear response from the ski.
If I was you, I would turn both low speeds out 3/4+ of a turn, see what happens to the idle, adjust that to 3K & retest in the water. If it seems to get better, its lean. unless water is a bit of a road trip, its an easy test.
I do like the idea of a pop off test with the diaphragm covers on, but, if your arms were bent that much to hit the covers, you probably would have noticed they were not very perpendicular to the metering block?
If I pull the choke for a restart, it really doesnt help at all, actually it hurts it, there is no way it would start with the choke closed. Usually I just hold the throttle wide open to get it started.
It is not a pop off test with the covers, just 10 psi to make sure that the needle and seat will hold pressure from the tank.
Gotcha
personally, If your ski was in my shop, I would let it warm up on the hose, then check the idle speed & maybe set it to 2000-2500rpm's (so you don't get lean run away) Then turn both LS screw in until you see the idle rise. if your at 1 turn out now, you might see it right away. at this point, its starting to go lean, & maybe too lean. Then I would back them out 1/4 turn at a time until the speed drops & stays dropped. somewhere just below the edge of the idle going up & 1/4 turn out is close to where you want to be with these carbs IMO. I had mine out 1/4 turn past where the idle speed dropped & it ran & restarted better than ever. it might have been a little rich but the 97's with the accelerator pump have really small ls jets.
I am at 1-1/2 turns out right now, which is the stock setting.
So tell me this, maybe I am just having a hard time understanding lean vs rich.
So I will start at stock settings, 1.5 turns out, 0 on the High, and 3000 rpms.
Im at 1.5 turns out now, if I turn the LS needle out and the RPM
rises then the current stock setting is too _______ (rich or lean). If I turn it out and the RPM
lowers, then it is currently too _______ (rich or lean?)
If I turn the LS needle in, and the RPM
rises then I am too ______ (rich or lean?) If i turn the LS needle in and the RPM
lowers then I am too ______(Rich or lean)
Lastly. Can I do any of this on the trailer with the hose and then "fine tune" it at the lake on the trailer.
While I am pulling the carbs tomorrow to check the PSI holding pressure, I will pull the RV cover and make sure all is time as well.
