speters427
Just tried to get my 99 SPX running for the first time after the long winter. Installed a new battery, cleaned all the terminals. Found that water must have gotten into the rear fuse box (major corrosion at the bottom coil post, and the bottom fuse was completely rotted away). I took the rear fuse box to the local Sea-Doo dealer as I was concerned that the whole box was toast, he seemed to think that the coil is virtually indestructable, so I returned home and carefully cleaned all the connections and temperarily bypassed the destroyed bottom fuse by soldering the wires together, hoping that would get my running. Wrong. The system is totally dead, can't even get it to beep. The counter guy figured it was the MPEM and the cost for that is about $700....Ouch! I took the front fuse box and MPEM out and inspected it and it looks brand new. Front fuses are fine.
Any suggestions would be greatly appreciated.
