99 GTX won't turn over
Mike77802
Last time aI used if it started, ran great for about 10 minutes, then started running about 3/4 speed and didn't sound right, low voltage light started flashing then oil light by the time got back to the trailer. Went to look at it the next morning and it wouldn't turn over at all. Battery is good.
So, motor will not crank over, with a new battery, while you hit the start button, correct?
Remove the sparkplugs, and the grey shield at back of motor, and turn the pto, to make sure the motor aint froze.
Does the motor do anything when key is on, and hit start button? Do you here a clicking sound?
doublecheck to make sure battery is good. If it is, then locate the black ebox, and where the 2-red leads attach to, jump that "relay". If motor turns, then probably a relay. It should'nt however, contribute to the low volt flashing though.
Make sure, oil is full, gas is in tank, fuel selector on "res", inline fuel filter has fuel in it.
x2 on that!!
Might also check both ends of the battery cables for corrosion, especially the positive cable going to the starter. Those connectors over time will corrode internally and look really good on the outside.
Just my 2 cents!!
OK went to go jump the solenoid and when i put the battery back on it doesnt do anything now, doesnt beep anything. The battery reads 13 volts.
